New to this....
By NYYanks120 · Oct 16, 2011in General💬 4 posts👁️ 1,215 views
Posted Oct 16, 2011 · 20:57 UTC#1
Guys i just bought a jetta and the Pioneer AVIC-F700BT is installed....
i have a few questions...havent messed with head units in a while.....
1. I know its XM read because the previous owner has the XM antenna mounted on dash.....i have an XM radio to install into it, but how do i go about it? what do i have to do? my unit is an audio vox i just have no clue..
2. my usb isnt working properly. everytime i connect iphone/ipod it shuts the unit off.
3. i am reading a lot about a firmware update? how would i go about doing this?
any help on here, or my email ([email protected]) would be greatly appreciated
thanks guys
Posted Oct 16, 2011 · 22:36 UTC#2
Also how come the auxiliary jack doesn't work?
Posted Oct 20, 2011 · 19:39 UTC#3
well that might not be the XM antenna that might be the GPS antenna on the dash. To install XM you need this http://www.crutchfield.com/S-yilQjKyGDnG/p_130P920XM/Pioneer-GEX-P920XM.html it plugs into the back of F700BT.
could be a bad cable or you need a the firmware update.
check to make sure you dont already have the latest version. Goto "settings">"system settings">"service information". if you have have version 3.x or 4.x you already at the latest version. There's instructions here on how to do a firmware update if you need it, do a "search".
4. Also how come the auxiliary jack doesn't work?
here's the link to the manual for your unit http://www.pioneerelectronics.com/StaticFiles/Manuals/Navigation/AVIC-F700BT_OperationManual0722.pdf i recommend looking it over. Goto Page 143 of the PDF, it shows you how. Goto "settings">"AV settings" . page 143 will tell you how to turn on the "mini-jack input on the front panel".
Posted Oct 25, 2011 · 00:41 UTC#4
well that might not be the XM antenna that might be the GPS antenna on the dash. To install XM you need this http://www.crutchfie...GEX-P920XM.html it plugs into the back of F700BT.
here's the link to the manual for your unit http://www.pioneerel...nManual0722.pdf i recommend looking it over. Goto Page 143 of the PDF, it shows you how. Goto "settings">"AV settings" . page 143 will tell you how to turn on the "mini-jack input on the front panel".
thanks for all the help....how can i tell if the antenna on the dash is for the GPS?
also how come my AM radio comes in so poorly?
