Z3 Gyroscope problem / unit is FREAKING OUT
By beckerwp · Oct 17, 2011in Problems/Troubleshooting💬 5 posts👁️ 1,430 views
Posted Oct 17, 2011 · 03:39 UTC#1
Not really sure what happened to my Z2 (HD upgraded to Z3) I've had it installed in my car for about 5 years. Yesterday I noticed that when I was navigating, when I would stop at the light my location would start to creep forward, but when I started driving it would be correct, except sometime just "next" to the road I was actually driving on. I decided to look at the meters and see what it was doing and it was acting crazy (see the video HERE) even though I was stopped, The speed and G sensors were going crazy giving lots of random readouts.
After that I decided to go into settings and look at the connection stats - a popup came up that said something to the nature of the "g-sensor position error". After which, when I went back to the map meters screen all the sensors had an error window covering them (see attached picture).
I don't know what could be causing it. I haven't removed the radio or added anything to the car in a LONG time. It just started happening randomly.. and since then it hasn't gone away.
My next step is to try a battery pull. I don't think that is really going to fix it.
does anyone have any idea what could cause it? or what I could do to fix it?
Posted Oct 17, 2011 · 20:19 UTC#2
Try a simple reset first. check your connection status menu to see if you have GPS sat signals and VSS is working correctly.
Posted Oct 23, 2011 · 03:51 UTC#3
The GPS is strong, and the VSS works great when I'm moving. I did all the resets I could find (including a battery pull) I've noticed now that sometimes it works fine, then it randomly starts freaking out. I was able to trigger a freakout the other day by doing a .5g brake.. I think that maybe the Gyroscope(s) are sticking or shorting out somehow.. :-\ any ideas what I can do to help?
Posted Dec 11, 2011 · 12:39 UTC#4
Im having the same problem with my Z3 did the reset but it works for about 3 minutes and then my arrow is all over the place can anyone help please??
Posted Dec 11, 2011 · 15:23 UTC#5
If you have already done a hardware reset, then try resetting the 3d calibration, after you confirm sat signal and vss are both working correctly.
