Mic volume too low
By mikedecaro · Oct 20, 2011in AppRadio, AppRadio 2, AppRadio 3💬 15 posts👁️ 11,495 views
Posted Oct 20, 2011 · 03:25 UTC#1
Anyone have problems with the microphone being too low? People can't hear me when I make phone calls.
I'm looking into replacing the microphone with a powered one that would let me increase the volume. Has anyone done this and/or know anything about powered mics?
Posted Oct 21, 2011 · 05:17 UTC#2
I am having the same issue. The mic I used when I had my parrot mki9200 was awesome, everything said they couldn't even tell I was in my car and it wasn't powered. It had dual heads, I doubt it fits the standard jack that the appradio has though. I would love to replace mine.
Posted Oct 24, 2011 · 02:45 UTC#3
These mic's seem to mostly be junk. I swapped mine out tonight with a mic from my U310BT and all is resolved. I did have to purchase a 5/32 to 1/8 adapter for the plug, but I am happy to have the problem fixed...
Posted Oct 24, 2011 · 15:19 UTC#4
I've just fitted this unit and was going to use my old F900bt mic, guess what different size. Why do Pioneer bother to make everything so awkward. I didn't realize there was an adapter, where did you get yours from?
Posted Oct 24, 2011 · 15:34 UTC#5
3.5mm male to 2.5mm female?
Posted Oct 24, 2011 · 16:00 UTC#6
Is the mic powered/amplified? or is it just a better quality mic?
Posted Nov 07, 2011 · 01:56 UTC#7
Hey guys, Sorry I have not checked the forum lately. I actually had a little typo. The plug size is 3/32" not 5/32". This is the same as 2.5mm to 3.5mm and yes, the 3.5mm (1/8") is male which plugs into the head unit and the 2.5mm (3/32") is female which the Mic plugs into.
Mike, to answer your question, the microphone is not amplified, it just seems to be a better quality. I hope they eventually add a gain setting like other manufacturers...
Following is the adapter that I purchased. Cheap but it works.
http://www.radioshac...oductId=2062457
Edited Nov 07, 2011 by 4S4s
Posted Nov 09, 2011 · 23:10 UTC#8
Update: I have had the opportunity to drive a bunch over the last couple of days. The microphone swap is not the savior I hoped it would be. While the quality is better, it is still not as good as it needs to be. Many times I have had to switch back to the headset as callers could not hear me. Oddly some folks say the clarity and volume is very good while others can barely hear me. It is almost as if there is an issue with the AppRadio occasionally utilizing the phone's mic vs the external... Ideas?
Posted Nov 12, 2011 · 07:36 UTC#9
I've got this problem as well. If Pioneer would add a mic gain/boost setting to AppRadio it would fix this issue.
Posted Dec 05, 2011 · 21:50 UTC#10
I called Pioneer customer service about this issue. The guy on the phone insisted there was nothing wrong with my mic and that he could hear me just fine. As soon as I hung up, I called a few of my friends to test it out and they could hardly hear me. Sounds like they just don't feel like fixing the problem.
Posted Dec 13, 2011 · 18:00 UTC#11
i was changed my AppRadio mic to my old DEH6100BT mic...
Posted Jan 03, 2012 · 03:21 UTC#12
Is there an improvement?
Posted Jan 05, 2012 · 04:39 UTC#13
I went into the settings general. There is an option, far right, 3 bars, that brings up 3 options including hand free. I upped the volume to 3. Now people say they can hear me great.
Edited Jan 05, 2012 by ronsno
Posted Jan 06, 2012 · 05:43 UTC#14
nice, I'm gonna try this out.
Posted Mar 07, 2014 · 08:40 UTC#15
I've had a weak microphone for the last few months.   People hated talking to me while I was driving around via appradio 3 so many phone calls were cut short.  They said it sounded like water was sloshing around in the background.   I have a convertible but the top was always up.   The mic is placed in the upper left of the windshield for more others have it.
This is an easy fix. (after I finally learned)     I didn't notice the setting right in front of my face the whole time.  I had Vol (Volume) set to medium(2 bars) instead of high (3 bars)
Are people saying the Mic is too low even with max mic vol setting?
Edited Mar 07, 2014 by JazJon
