Any way to remove pushing OK upon powering on?
By pghjerry · Oct 21, 2011in AppRadio, AppRadio 2, AppRadio 3💬 24 posts👁️ 8,058 views
Posted Oct 21, 2011 · 01:06 UTC#1
Is there any way to remove pressing OK each time you turn on the radio?
Surely I can't be the only one that is sick of agreeing to whatever the screen says every time you start the car, lol.
Posted Dec 29, 2011 · 22:40 UTC#2
I fixed mine with a custom firmware...
Posted Dec 30, 2011 · 06:09 UTC#3
Got it from somewhere or modded it yourself?
Posted Dec 31, 2011 · 08:53 UTC#4
Haha you need to tell us more !
Posted Dec 31, 2011 · 21:31 UTC#5
I'll pay you for the fix:)
Posted Jan 01, 2012 · 23:03 UTC#7
When you say used, what do you mean exactly? I'd like to do this myself
Posted Jan 02, 2012 · 00:55 UTC#8
Nope, I got it here. I used the FX 3.1 firmware....
http://avic411.com/i...firmware-image/
Yes, the guides on that thread are for other radios than the appradio so the instructions for button presses and methods don't apply to our radios. What steps did you do to get it to work on your appradio?
Posted Jan 03, 2012 · 03:54 UTC#9
Clearly he was posting in the wrong forum, got everyone excited for no reason
Posted Jan 03, 2012 · 03:56 UTC#10
He was referencing a post from early 2010, the appradio wasn't even released yet
Posted Jan 03, 2012 · 20:19 UTC#11
son of a!
haha
Edited Jan 03, 2012 by grradams
Posted Jan 24, 2012 · 22:20 UTC#12
it works with custom re-pack.... interface only in russian, if you want i will post link here
Posted Jan 25, 2012 · 04:17 UTC#13
I'd like a link
Posted Jan 25, 2012 · 17:25 UTC#14
sorry, i'm use google translate for repack instructions...
"AppRadio + - build additional configuration, scripts and programs that enhance series Pioneer units AppRadio (model SPH-DA01).
AppRadio + provides the following capabilities:
- Launch of external navigation software in conjunction with regular operating envelope,
- Connect to the Internet using an external usb-modem as a modem, mobile phones can act, gprs-modem, cdma-modem, etc.
- Launch other external programs that the user requires.
I thank all the participants of the forum 4pda.ru for assistance in the preparation of this assembly, and special thanks to: carver_ua, Shtorm (3ppc.net), MalVal, djskam.
To connect the modem using usb-port for iphone, pre-attaching an usb-hub, may also need to add. power to iphone, connected through a hub, could be charged if there is a hub of other devices. Thus, a hub can poklyuchat usb-stick and other devices.
In order to have earned the phone (usb-modem) on the usb-connection as a modem for Internet access should be added to the assembly prior to its installation on the machine settings for your phone (modem). To define the settings for a particular model phone (modem), as described here do
You can also read here how to pick up your phone to work with the driver used.
After that, you should get the reg-file that defines the settings for your phone, its structure should be as follows:
REGEDIT4
# Instead will be given your XXXX_YYYY_Z numbers that correspond to your phone [HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z]
[HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z \ Default]
[HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z \ Default \ Default]
[HKEY_LOCAL_MACHINE \ Drivers \ USB \ LoadClients \ XXXX_YYYY_Z \ Default \ Default \ RS23
2_USB]
"Index" = dword: 00000009 # defines to which port to start the initialization
"FriendlyName" = "USB modem" # here should be the name of the device may be any and it will be used in the connection settings as the name of the modem
"UsbMode" = dword: 00000000
"SendEndp" = dword: 00000002 # important parameter, it determines the right to use your phone as a modem
"ReceiveEndp" = dword: 00000082 # important parameter, it determines the right to use your phone as a modem
"ClassEndp" = dword: 00000081 # important parameter, it determines the right to use your phone as a modem
"DeviceType" = dword: 00000001
"Tsp" = "Unimodem.dll"
"Prefix" = "COM"
"Dll" = "232usb.dll" # check that the name of the dll mentioned here as
Place the resulting file to a folder AppRadio \ System \ Registry under any name with the extension reg
Setup and installation of the assembly
Important: The current version of the assembly will only work with version 2.22 firmware device, if you have another version, the official firmware update as usual.
Carefully read the description of the set up and run an assembly:
Spoiler (+/-)
1. Unpack the archive to the memory card in the root directory cards shall be placed AppRadio and files:
- Cetool66.exe
- Cetool66.mscr
- Mortscript.exe
- Toolhelp.dll
2. Insert the card into the machine and reboot the device (do a hard reset), and the machine should be booting in safe mode and will launch testmode installer assembly.
3. Follow the installation instructions, the first installation of the assembly is recommended first to claim 1, "Installing the Assembly."
4. After successful installation, you must re-do a hard reset the device (the installation program will remind you about this before the release).
5. After installation, assembly loading apparatus must pass regular way (with the screen may momentarily appearance of programs to run in addition to the functioning of the assembly). On subsequent inclusions apparatat should also automatically clicks OK on the standard warning that appears at startup.
6. Log in extended menu by pressing the button on the standard settings (in order to still get into the settings to exit the advanced menu on the 'Heads. Menu "from the top bar). The expanded menu is implemented in the style of the iPhone and AppRadio and allows you to scroll the screen horizontally.
7. The expanded menu is implemented by the application iPhoneToday. In the current implementation, customization, adding, deleting programs is possible only by correcting the configuration file: icons.xml, system.xml, are to assemble at: AppRadio \ System \ Menu \ For the changes to take effect, the corrected files to be added to the assembly and make it update by running Setup from the expanded menu.
8. To set up Internet connections, you must run "App. is connected. "from the top bar menu and an extended follow its instructions. To the selected connection is established automatically assign it to the status of "active compound".
9. For automatic initialization and control of the compound is in the process of program "Connector" in the top bar. It also starts automatically when you first start the navigation software using the Internet connection (it is set up in launching the navigation program script).
10. Navigation and other programs should be in a folder at the root of APL SD-card, USB-flash drives or in memory (NAND FLASH), the initial startup scripts are set to this folder." - Serhy
AppRadio_plus_01.rar
Posted Jan 25, 2012 · 18:18 UTC#15
Could I have a link to the original thread? If i Have to register somewhere that's no problem, i just don't know if i should be looking through 4pda.ru or 3ppc.net.
Posted Jan 26, 2012 · 01:04 UTC#17
I'm sorry but i'm not sure exactly what this will do. Can i just down load the Rar file and use it to update my Appradio? Or will I need to edit some stuff?
Posted Jan 26, 2012 · 11:37 UTC#18
ijc1976, just download and put unpacked files into root of SD card... then follow instructions.... in near time i will translate installer msgs...
Posted Jan 26, 2012 · 14:02 UTC#19
I tried to clean up the installation part of the instructions:
1. Unpack the archive to the memory card in the root directory. Root directory should have The Appradio folder and these files:
- Cetool66.exe
- Cetool66.mscr
- Mortscript.exe
- Toolhelp.dll
2. Insert the card into the machine and reboot the device (do a hard reset), and the machine should be booting in testmode and the installer should launch.
3. Follow the installation instructions, if the re-pack is installed for the first time, it is recommended to select 1, "Installing the Assembly." (УÑтановка Ñборки)
4. After successful installation, you must do a hard reset (the installation program will remind you about this).
5. After installation, the device should load normally (some of the programs required for the re-pack to function might momentarily appear on the screen). On subsequent startups the OK should be clicked automatically.
6. To get to the extended menu press the the standard settings button (in order to still get to the settings you have to exit the extended menu on the "Main menu" (Глав. меню.) from the top bar). The expanded menu is implemented in the style of the iPhone and AppRadio and allows you to scroll the screen horizontally.
7. The expanded menu is implemented on the base of iPhoneToday application . In the current implementation, customization, adding, deleting programs is possible only by correcting the configuration file: icons.xml, system.xml, located at: AppRadio \ System \ Menu \ For the changes to take effect, the corrected files have to be added to the re-pack and the update has to be ran from Setup from the expanded menu.
8. To set up Internet connections, you must run "connection settings." (ÐаÑтр. Ñоедин) from the top bar of the extended menu and an follow instructions. For the selected connection to be established automatically assign it to the status of "active conection".(активное Ñоединение)
9. For automatic initialization and control of the connection there is a "Connector"(Коннектор) program in the top bar. It also starts automatically when you first start the navigation software that needs the Internet connection (it is set up in launching the navigation program script).
10. Navigation and other programs should be in a folder APL in the root of the SD-card, USB-flash drives or in memory (NAND FLASH), the initial startup scripts are set to this folder." - Serhy
I haven't connected my radio yet so I haven't tried installing it. So as of now I wouldn't advise it if you cant read Russian/ not willing to figure it out.
Posted Jan 26, 2012 · 14:19 UTC#20
thats right ;)
Edited Jan 26, 2012 by djskam
Posted Jan 26, 2012 · 14:22 UTC#21
and this procedures can't kill your device...
Posted Jan 28, 2012 · 09:12 UTC#22
it is the custom firmware that everybody wait, you are the owner of this custom firmware? can you tell us whether a multilingual version will be available or Is there a procedure to change the language ? I am really looking forward to read from the time we expect an evolution
Edited Jan 28, 2012 by Dejan
Posted Feb 01, 2012 · 17:16 UTC#23
Excuse me for this reply, but I'm having a hard time fully following this communication. Will this process get rid of all the annoying messges and OK buttons. If I do this will my appradio just work as it should, no raodblocks to using any features. This would be fantastic :mrgreen: I read this is in Russian, has it been converted to english. I just updated to the latest 2.45 firmaware from Pioneer, will this work with the latest firmware. If not I can reinstall 2.2, I saved it. Thanks.
Posted Feb 02, 2012 · 19:43 UTC#24
djskam you know to desactivate keybord on boot ??? i have tested to edit autorun but not succes :(
And its possible you upload Igo ?? if my thins its right we can install all windows mobile application in appradio ???
thanks a lot !!!
