Avic- Z2 sub output not working?!!
By kjsj · Oct 22, 2011in Problems/Troubleshooting💬 5 posts👁️ 1,078 views
Posted Oct 22, 2011 · 01:23 UTC#1
My amp came unhooked while I had the car on and now my sub output doesn't work anymore!.. Has this happened to anyone else or does anyone know how to fix this? I tested the sub output with a voltage meter n it is completely dead. Can i buy a new harness?! Is there something inside I have to do?! Or is it just fried?!
Posted Oct 25, 2011 · 17:50 UTC#2
Did you check the menu settings? Is your amp connected to the amp switch wire or the power antenna wire.
Posted Oct 28, 2011 · 02:31 UTC#3
everything is hooked up right and was working fine until it came unhooked. I feel like it shorted something out I might just try buying a new rca plug!
Posted Oct 28, 2011 · 14:44 UTC#4
Did you check the amp's fuse?
Posted Nov 04, 2011 · 05:22 UTC#5
After I tested it and found out it wasn't working I just pulled the cord and plugged it back into the converter I was using with the stock stereo and everything worked fine. It has to be something inside. I am just hopping there is a safety switch or something and its not shorted out!!
