New z130bt installed. Can't change any settings.
By devious · Oct 23, 2011in Problems/Troubleshooting💬 4 posts👁️ 1,743 views
Posted Oct 23, 2011 · 13:16 UTC#1
Hello,
Just installed z130bt in 05 4runner....
Install didn't go to well, the installer took over 5 hours, and it is still not working properly :-(
I advised him about the bypass, but I dont think he did it, I think I remember seeing the mute wire dangling not connected to anything at all ?
He finally gave up and told me to come back, to run the wires for rearview camera, and also to tap reverse light from the back as he coulnd't find the reverse wire from the shifter harness?
I don't think that will work, but anyhow.
He also mentioned something about the speed sense wire also not being connected.
He also could not find control wire 2 so my AWCS steering interface isn't working either....
I think I told him properly how to do the diversity antenna connect properly (three wires, one normal antenna jack, a smaller one then a power line)
So my new z130bt turns on and regardless if I am in park with my e-brake on, it thinks I am driving ? I can't edit any BT setting to sync my phone, can't watch any video either.
Does anybody know if the z130bt is hooked up stock, but the mute wire, and speed sense wire are not hooked up, would this be why the unit thinks I am always driving,
even thought I am in park with e-brake on ?
I hope the installer at least found the e-brake wire ? but can't confirm. Are there any soft/key hacks ? ie press and hold eject + volume up ? Or do I have to wait until next week for the tech to try this again ?
I can' believe I can't change any bt or nav settings, at least I can listen to mp3's..
Thanks in advance for any ideas, and if any one has this unit in a 03 - 07 Toyota 4Runner, please drop me a line and advise how your install went.
Thanks.
Posted Oct 23, 2011 · 14:54 UTC#2
The unit is not installed properly and its not going to work until it is fixed. I would make sure they fix it and then never return. There really is no excuse for the issues you are having after a professional install.
Posted Oct 23, 2011 · 21:16 UTC#3
Hmmmm I believe I have this same problem but why can we click on some icons? Like I can navigate and put in CDs but they don't get the titles read and I just sort of figured out how to play my iPhone 4 on it but I cant do any settings stuff or blue tooth the only settings I can do are av settings and I too can't watch movies I put in the actual DVD of grown ups and I could hear like a start up screen but no picture to do anything with it...I can only navigate with the voice recognition I can't do any typing or any other buttons it offers me.
Edited Oct 23, 2011 by King_corral
Posted Oct 24, 2011 · 16:23 UTC#4
Haha ok I know I needed the brake but I meant I had my car in park not my emergency brake that's what I needed to put on... I put my e brake on and it all works fine... I can't do Facebook and I'm not to sure how to use my appradio app on my iPhone 4 I'll probably try the bypass myself...
