My question if the appradio has the power antenna and power amp together ?
How to install video bypass in pioneer appradio
Hi
I've done the bypass with the relay. This is what I've done and is working a treat.
Relay pins
85 - blue w/ white stripe (From Radio)
86 and 87 - ground (connect to black wire on the radio harness)
30 - green w/ white stripe (From Radio)
Ok where I can buy the relay?
Hi
Any automotive 12V relay will do, Ebay, Halfords..
I was try to install the realy but it doesnt work the only way that let me watch videos is with an switch.
The relay when the car is on it works if I connect and reconnect like switch , but when I turn off the car and start again It doesn't work ,
In the latest software revision others have mentioned they expanded the brake checking crap. I used to only have to hit my button once to get to watch movies, now I have to hit it twice. I don't think a relay will work anymore since they're now requiring a dual pulse instead of a single one.
