I have an AVIC-Z1 that I have been using the iPOD control cable to control my legacy iPOD on for years. It worked fine. I upgraded to an iPOD touch and now I get a message up on my iPOD Screen that says that this device will not support charging. It plays my iPOD touch just fine but will not charge it. The down side is that I have to take my iPOD Touch outside of my truck an charge it that way. Any recommendations on cables that will work to support charging my iPOD Touch on my AVIC-Z1? ![]()
AVIC-Z1 iPOD Touch Charging Support
The exact error message I'm seeing on my iPOD Touch is "Charging not supported with this accessory". I never seen this with my old iPOD. Is there a different supported interface for the AVIC-Z1 that will support charging?
anyone ? ![]()
I have the same problem! Still researching but I think this device might do the trick: http://www.amazon.co...e/dp/B001HN6CVA I want to confirm before I purchase it, I have an iTouch 4th gen
Update.. it doesn't support Pioneer..
Compatibility: The passPORT is compatible with the following iPods (as of October 2010):
- iPod touch (2nd/3rd/4th gen.)
- iPhone (3G/3GS/4)
- iPod nano (4th/5th/6th gen.)
Note: The passPORT is not compatible with the following stereos:
Pioneer: Pioneer head units using the CD-iB100 or CD-i200 iPod to IP-Bus adapter
Mercedes: vehicles equipped with the Mercedes Media Interface Cable
BMW/Cooper: vehicles equipped with an iDrive iPod Interface
http://www.crutchfield.com/S-NrRuz7jhOis/p_142IFWA/Scosche-passPORT.html#details-tab
More googling, this thread http://www.cablejive.com/forum/viewtopic.php?f=22&t=19 points to this device http://www.cablejive.com/products/Car-Charge-Kit.html that works. It adds a mini usb car charger to compensate if the device cannot convert the power inline.
I have chose to try the Cablejive solution that you pointed out. I like the fact that it has an external power source. I think the only downside is that it may have a problem with syncing power. You have to start the car before you connect the iPOD Touch. I keep my iPOD touch in my glove box out of site. So I may have to alter that and put it in a location that is no longer out of site. I will try it both ways to see if this is a probelm and will report back here.
In the meantime I want to thank you VERY much for your help!
Jargin ... GREAT news! I received my Cablejive cables today and my AVIC-Z1 now charges my iPOD Touch as it used to charge my iPOD. The Cablejive solution is a bit pricey but a whole lot cheeper then replacing my entire Navigation System. I wound up purchasing the extension cord because I like to hide my iPOD touch (out of site). Thank you VERY much for the rcommendation. This worked perfectly! ![]()
Schosce makes an adaptor to charge the Iphones and touches. They charge from the 5v source where as the older ipods charged off of firewire support which is 12v. I use one on my audi interface. I got the adaptor at best buy I think, or off ebay...
http://store.apple.com/ca/product/MC748ZM/A
I installed this on My Z2. plug the A/V into the back and run the USB cord to your 12v acc port. Now I have netflix, youtube, and even some racing games that will display on the screen. It's nice too because you don't have to use the avic interface for music... just the ipod!
