X930BT new install problems
By Snidor · Nov 01, 2011in Problems/Troubleshooting💬 7 posts👁️ 1,908 views
Posted Nov 01, 2011 · 22:27 UTC#1
Deck was installed today by a reputable installer.
Once I arrived home I activated the Sat radio and then wanted to get into the setting to make some changes. I'm not able to access any of the menus - not for the Nav, BT or Audio.
Am I correct in my thinking that they may have made an error and that the deck isn't seeing the truck in park?
Vehicle in question is a 2008 GMC Sierra.
Any input is appreciated.
Thanks.
Posted Nov 01, 2011 · 23:02 UTC#2
very good chances the installer did not hook up the Parking Brake properly
and that is whats going on
first thing in the AM i would call and notify them or better yet drive there and let them know you think they did not hook it up properly that way they cant tell you on the phone they have no time now
Posted Nov 02, 2011 · 00:08 UTC#3
Problem solved.
I was correct in my assumption.
I tore that apart and decided to do the bypass while I was in there. Everything is working now!
So far I like it!
Posted Nov 02, 2011 · 01:03 UTC#4
i would still call the shop and let them know what was going on maybe they should refund some of your install labor cost since they only did part of the job
Posted Nov 04, 2011 · 23:10 UTC#5
did they not hook it up at all, or did they hook it up to the actual parking brake, and you just were not setting the brake?
Edited Nov 04, 2011 by 1loudls
Posted Nov 08, 2011 · 22:53 UTC#6
It was incorrectly hooked up to the wrong wire. Their intention was to hook it up to the parking brake.
Posted Nov 08, 2011 · 23:26 UTC#7
wow that a pretty big epic fail since almost all parking brakes only have one wire coming off of them.
