Z 130 bluetooth echo
By StuGacy10 · Nov 09, 2011in Hacks/Mods💬 4 posts👁️ 1,649 views
Posted Nov 09, 2011 · 11:24 UTC#1
I am getting complaints from people i speak with bluetooth. They are saying they can here me fine but they are hearing their voice echo. Any ideas i tried the echo setting on or off i believe its the same both way.
Posted Nov 09, 2011 · 22:03 UTC#2
it may be where you have the mic sitting maybe try to place the mic in a new location
try to avoid it bearing near the window
and alos try to make sure there is room behind the mic for air to pass threw
Posted Dec 05, 2011 · 18:23 UTC#3
Also turn down the volume that you listen to their calls. I've noticed that the higher the speaker volume - the more echo.
Posted Dec 17, 2011 · 03:17 UTC#4
there is a system setting to defeat the echo problem.
it works quite well.
i can't remember exactly which menu it's in but i turned it off by accident while playing around and everyone i talked to via BT complained of the echo.
i went back into the system settings, found the echo defeat, turned it on and all is well again ever since.
