Newbie needs help with Z130bt install
By mike4100 · Nov 12, 2011in Problems/Troubleshooting💬 4 posts👁️ 1,333 views
Posted Nov 12, 2011 · 18:44 UTC#1
I installed a Z130bt in my 2010 Honda Ridgeline RTL yesterday.
I did the bypass mod. Moved the yellow mute wire up one spot then grounded it to the factory harness with the green parking brake wire and the HU`s ground wire. I also connected the speed sensor wire to one of the wheel sensor wires behind the passenger kick panel. When I check the connection status it shows the parking brake is on even when I`m moving, yet I can`t access half of the things in the nav menu until I stop. What is my problem? Thanks, Mike.
Posted Nov 13, 2011 · 20:25 UTC#2
I found that the yellow wire pin wasn't pushed in far enough. I fixed the pin and now I have full control of the nav and can watch dvd's while moving.
Now I have to figure out why my deck won't connect to my iPhone 3gs using the Pioneer cable.
Posted Nov 13, 2011 · 21:22 UTC#3
Where did you buy the cable?
Posted Nov 14, 2011 · 23:19 UTC#4
Well it turns out taking strong pain killers for a back injury before installing a new head unit in your car is a bad idea. The plug for the USB wire wasn`t pushed all the way into the HU. I can now connect my IPhone to my deck.
