IP-Bus as AUX Video Input
By J-Dub · Jan 22, 2007in General💬 6 posts👁️ 2,518 views
Posted Jan 22, 2007 · 08:05 UTC#1
A while back, I found on this forum an adapter that would let you use the IP-Bus as an AUX A/V input. Does anyone here know of that adapter?
Thanks in advance!
Posted Jan 22, 2007 · 18:04 UTC#2
It won't be an A/V input, only audio. There are several adapters you can use from Pioneer, Peripheral Electronics, PAC and many other companies. One from Peripheral, the PXA-02, will give you an iPod input, rca's and a 3.5mm headphone jack on one unit. What do you need it to do?
Posted Jan 22, 2007 · 18:07 UTC#3
why not just use the av input that the avic already has?
Posted Jan 22, 2007 · 19:13 UTC#4
Yeah, what he said.
Posted Jan 22, 2007 · 19:43 UTC#5
I plan on using the AUX input for my factory DVD. I already have the wires set up and it worked with my AVH-P6500DVD HU. I'm wanting to integrate my Zune w/ video for playback on the Z1 screen. I just thought that since you can run a DVD changer through the IP-BUS there would be an adapter to run video. I swear I saw something on this forum about six months ago while lurking here.
Another idea...anyone ever tried one of those video switcher units and can make a recomendation?
Posted Jan 22, 2007 · 22:58 UTC#6
The Pioneer switcher works pretty well, looks cool, and is easy to use, even for kids. http://www.pioneerelectronics.com/pna/v ... 92,00.html The IP-bus only carries audio and command information.
