I have a F90BT with 3.0 firmware and I have an Ipod Touch 3rd generation 32GB. My problem is when I connect the Ipod to my radio the Ipod says charging not supported by this accessory. It plays everything on the ipod just fine and will control it just like it should but it just will not charge it. I have the actual Pioneer Ipod cable not a generic cable. My girlfriend has an Ipod Nano and it charges hers just like it should but it will not charge my Ipod Touch. What is wrong with it?
F90BT and Ipod Touch
after a certain point, apple (being the cool people that they are) changed which pins in the 30 pin dock connector handle the charging, therefore rendering a lot of all the accesorys useless that people already had for their ipods if they wanted to upgrade to a newer ipod. thanks apple!
now there are adapters out there that plug in between the ipod and the cable that fix this problem, but i have seen a few times where this would not work.
one such model is the scosche passport.
Yes,the adapters will enable you to connect your ipod to F90BT.Then you wil have full control over your ipod from the touchscreen car dvd.
well he already has full control over his ipod through the touch screen, its the charging that he is having a problem with.
also not really sure of the random link to a random website.
