Hello, everyone... I've been lurking here for about a month (thanks to all for many great tips!), and just had a Z130BT installed in my 2006 4Runner. Using the PAC-TATO to interface with the stock JBL amplifier. Everything seems to be working well with the unit, but after reading several posts discussing the improved audio quality after using Auto EQ, I found the CD-MC20 microphone in stock on Amazon and went through the process yesterday to the letter.
My first thought was "WOW" - it made a huge difference, and I loved the way things sounded with Auto EQ on and "Powerful" selected. After listening for a few minutes, I started noticing slight drops in volume that last for about one second, then the volume returns to normal. The issue reoccurs about once per 30 seconds, which is enough to be annoying.
The issue is prevalent regardless of the source - I've experienced the same results with music from HD Radio, a regular CD and my iPod. I've also experimented with other settings such as Subwoofer on/off or at different frequencies, HPF at various settings and off, and the issue persists. I thought perhaps the combination of Auto EQ and "Powerful" might be pushing the amp, so I tried Auto EQ and "flat" as well as "natural", and the issue is still there.
The only way to prevent it is to turn Auto EQ off. I've tried my best to replicate the sound using "Custom1" EQ, but can't get it quite dialed in.
Has anyone else run into this issue? Any suggestions for potential troubleshooting steps? I do plan to re-run Auto EQ today, but wanted to check in here first...I did search the forum and was unable to find the same issue.
Jason
