Hey guys, being bothered by my install of the AVIC X930BT in my 2009 VW CC. The issue is that once its connected I no power. Regardless of whether the car is running or not. I don't consider myself a newbie but i'm certainly not a vet. Let me get to the details.
This is what I bought:
- METRA 99-9011 DOUBLE DIN DASH KIT
- AXXESS XSVI-9003-NAV
- METRA 40-EU55 ANTENNA ADAPTER
- Metra Axxess ASWC
Because the XSVI-9003-NAV was pre-wired for the ASWC, It made connecting the harnesses pretty straight forward. The following pictures of how i connected the harness. I tried to get every wire explained.
Everything looked good so i went ahead and disconnected the battery on teh car, took out the stock radio and plugged the power harness and the rca connector into the HU. Made sure the airbag connection was made before connecting the battery And connected the battery only to find out the HU had NO power regardless of the car being turned on or not.
Time for the Multimeter. First started with just the harness, hoping there was a bad connection. Because my issue is power, i only need to test for the 12v wire and the ground. I had a connection through the harness so the harness was fine. So i plugged the harness into the factory harness to see if i was getting 12 volts. Sure enough, i got 12 volts at the end of the harness. So what could my problem be? Besides a fried HU of course.
Pictures should work but let me know if you can't see them. I have comments on each picture explaining what it is.
Thanks in advance for your help guys. Would love to get this figured out or at least something to try once i get home from work.
-Doug
