can't delet devices from bt in HU that have been saved and set up
By ThumperPup · Dec 02, 2011in Problems/Troubleshooting💬 6 posts👁️ 968 views
Posted Dec 02, 2011 · 20:44 UTC#1
ok so i am trying to figure out is the only way to delete a device from the HUs Memory for the BT to reset the entire HU settings ?
i really do hope that there is a way to just delete some of the phones and devices would suck
to have to reset the entire HU to factory settings
also if you reset to Factory settings does this also mean my PW will be reset and need to be set up again ?
Posted Dec 02, 2011 · 22:53 UTC#2
If I remember correctly, you can only delete when you have 5 devices and want to add a new one.
If you have 5 devices, try adding a new one and a delete menu should pop up. To do this without 5? I have no idea if you can. I haven't found a way.
Posted Dec 03, 2011 · 06:55 UTC#3
hmm ok cool thanks i know there are 4 right now 3 iphones and my Brothers phone i only have 1 of the iphones
i hope that it doesn't only let me delete just 1 phone to make room for more if thats the case that would still suck
thanks for the info going to add my dads iphone to it tomorrow and see what pops up
Posted Dec 04, 2011 · 02:24 UTC#4
nope does not work i now have 5 devices on there and cant delet any of them
Posted Dec 04, 2011 · 05:17 UTC#5
Once you attempt to add the sixth the first one will be deleted.
Posted Dec 04, 2011 · 06:27 UTC#6
ah ok cool so i need to go out and get a 6th device lol
hmm is there a way to save your settings on a SD card that way i don't have to reset everything manually again i can jsut load the SD card and load the settings from it
or is that not possible or if it is possible will that also reload the devices ?
