iphone contact transfer with 910BT?
By lipshurt · Dec 06, 2011in General💬 3 posts👁️ 1,168 views
Posted Dec 06, 2011 · 05:01 UTC#1
i have been searching this for hours, and can find no clear answer on if this is possible. I would say it is not based on my the fact that when i try to transfer my phonebook from the iPhone 4, it waits a couple seconds and then says that it failed.
I have found many posts saying transfers from the iphone are impossible, and others saying they are possible. Is there a trick? i found a trick with someone changing the format of your top forty numbers, but that is so hackish.
Basically i would like to hear someone who got it to work explaining how they did it. I have tried about everything. Some people say that the numbers load every time so it take a bit. I only have 80 numbers, so that would be ok. But that did not seem to be the case either.
thanks in advance. I have a 910BT, and the iPhone 4.
Everything works except phonebook transfer
Posted Dec 12, 2011 · 22:14 UTC#2
Last night, I was able to transfer my girlfriends contacts from her iPhone 4 to AVIC-X910. It took about 3 minutes to transfer about 100 contacts over.
Posted Apr 13, 2012 · 05:07 UTC#3
How did you do that?
