can not power unit off
By deftones500 · Jan 22, 2007in Problems/Troubleshooting💬 17 posts👁️ 2,942 views
Posted Jan 22, 2007 · 22:25 UTC#1
I can switch my source to off, but how can I power the whole unit off?
I do not want my amps constantly running, if i do not feel like using the unit...
Posted Jan 22, 2007 · 22:28 UTC#2
Not possible without installing a physical switch for the amps.
Posted Jan 22, 2007 · 22:31 UTC#3
arent the amps turned off when you go to the "off" source?
Posted Jan 22, 2007 · 22:35 UTC#4
Nope, they stay on for Navigation.
Posted Jan 22, 2007 · 22:42 UTC#5
aint that something, yeah put a switch on the remote.
Posted Jan 23, 2007 · 03:53 UTC#6
JasonH is exactly right and that's why he is our forum Administrator. What's up JH!
Cheers,
Kevin
Posted Jan 23, 2007 · 04:53 UTC#7
ohhh thats why huh.. jokingly smirks
Posted Jan 23, 2007 · 05:06 UTC#8
Uh huh! Yuk Yuk Yuk! LOL
Posted Jan 23, 2007 · 06:56 UTC#9
Gentlemen there is a very simple solution for this, if you aren't using the blue power ant lead.
Instead of using the blue/white trace which is the amp turn on remote lead, use the blue antenna relay lead.
Then in INITIAL menu change the auto antenna setting from RADIO to SOURCE. Now whenever the source is turned off the amps will turn off also. As noted though, you will lose voice guidence if you are not using the internal amp of the AVIC unit, since your amps are not powered on.
Chris
Posted Jan 23, 2007 · 15:27 UTC#10
thats what I was thinking... sure it operates that way? Ive never had the need to test it
Posted Jan 23, 2007 · 15:31 UTC#11
Well according to the AVIC-D1 Owners Manual and Installation Guide--Yes. I have not verified this, though.
Chris.
Posted Jan 23, 2007 · 18:34 UTC#12
How about them smart fellers over at Pioneer, building in a way around something they knew was gonna bother someone. 8)
Posted Jan 23, 2007 · 21:27 UTC#13
Hmm I guess I'll have to pull out my d1 and check this out. Let ya guys know in a bit.
EDIT:
Yup the power antenna (blue) wire does lose power when you turn the avic off. So the only down side I see to this is as was mentioned before the loss of voice nav when the unit is turned off.
Posted Jan 23, 2007 · 21:57 UTC#14
my guess would be that if you wanted the whole unit off you wouldnt be using the navi either huh
Posted Jan 23, 2007 · 22:01 UTC#15
Very true. Then again you have to account for everything. You know how often I've had people get pissed off at me because I removed the tape deck in their car to install a cd player? They always ask "why can't I have both?" or "I didn't tell you to take the old one out"
Posted Jan 25, 2007 · 17:42 UTC#16
I was actually giving this some thought the other day.
Using two relays and either an under dash cell phone handsfree speaker or even the drivers side speaker, you could wire up two relays as follows.
For a seperate handsfree type speaker:
Relay 1:
85-ground
86-blue ant wire
30-external speaker +
87a-front right + output from AVIC-D1/D2
87-NC
Relay 2:
85-ground
86-blue ant wire
30-external speaker -
87a-front right - output from AVIC-D1/D2
87-NC
Utilizing the front right speaker:
Relay 1:
85-ground
86-blue ant wire
30-speaker +
87- External Amplfier
Relay 2:
85-ground
86-blue ant wire
30-speaker -
87-External Amplifier
Posted Jan 25, 2007 · 23:16 UTC#17
Sounds a lot like the rig I have for running the 2 radios. It does work though.
