Z1 Built in Amp or VW Monsoon OEM AMP
By madonionrings · Dec 07, 2011in General💬 3 posts👁️ 1,328 views
Posted Dec 07, 2011 · 22:38 UTC#1
Which should be used for a install? I recently picked up a VW with a Monsoon OEM amp in the trunk with a AVIC-Z1 pre-installed. I am not sure if the amp in the rear is even wired to the head unit. Is there an easy way to check for this? Should I use the OEM Monsoon amp in conjunction with the head unit or the head unit alone?
Posted Dec 08, 2011 · 15:25 UTC#2
Anyone?
Posted Mar 27, 2012 · 21:17 UTC#3
You probably already installed this, But I used the Bose amp in my wifes 1998 Acura RL with great results.
