Recently installed the AVIC-D2 in my 2000 Jetta GLS. Here's a few notes for installing in a MKIV Jetta/Golf/GTI.
- Prepped the wiring harness, did the bypass hack and grounded the unused pin as well as the green parking brake cable.
- When I first fit the AVIC in the dash opening I could not push the unit all way in with IP-BUS cable connected. Removed the glovebox to route the GEX-P10XMT cables and ended up removing the entire radio cage (dash panels for the driver side must be removed, as well as the center console, see the vwvortex mkiv FAQ for this). With the radio cage out I could test fit the AVIC and see exactly where the IP-BUS cable was hitting the back of the cage. I removed a notch from the back of the cage using a pair of sharp pliers. The notch is just behind where the IP bus cable would be- about 1.5cm by 1.5cm. Now unit sits all the way in the dash. I was able to do a much better job routing cables with the cage out, its worth the extra work.
- The front bezel needed some shaving/sanding on the right side since the dash opening was just short of accomodating the bezel; probbably varies from car to car.
- Didn't bother messing with speed pulse cable at first, but since the dash was already apart I removed the speedo cluster with two torx screws just above steering wheel. Unwrapped part of the electrical/cloth tape protecting the cables to the blue (left side) connector. I located the blue wire w/ white stripe and tapped it using the Pioneer provided tap. (I determined which wire to use based on what people had posted on the internet for their mkiv jetta/golf)-- speed pulse worked- now D2 shows slope. Unless you have the dash apart its probbably not worth the effort to install speed sensing.
