Used z3 install issue - no audio on ipod or BT
By ballsie65 · Dec 23, 2011in Problems/Troubleshooting💬 4 posts👁️ 1,118 views
Posted Dec 23, 2011 · 02:04 UTC#1
I just bought a z3 on eBay and installed it. Ii installed the iPod, xm, and Bluetooth modules and I'm having issues.
I can connect my iPhone via Bluetooth, but there is no audio
The stereo is playing music on the iPod and I see the song data on the screen, but there is no audio
I guess it doesn't see the xm receiver, because I get no signal or radio ID on the xm status screen.
The nav iss way off. It shows me driving a half mile from the road I'm actual ly driving on.
Any help would be great. Thanks!!!
Posted Dec 23, 2011 · 14:14 UTC#2
Re the navigation:
1) did you hook up the speedpulse ?
2) did you reset the calibration on the Z3 after installing ?
Edited Dec 23, 2011 by jwq
Posted Dec 23, 2011 · 14:18 UTC#3
Xm: be sure the ipbus cable is connected correctly. It is easy to connect to the wrong port on the xm module. Also be sure the xm has power and ground.
For the audio: can you describe your setup? Amps? Speaker level outputs? Etc.
Posted Dec 23, 2011 · 17:09 UTC#4
I verified the the ip bus cables are correct.
04 gmc Yukon with Bose. I'm using a metro gmos-04 adapter to retain the factory door chime and Bose system. No other amps.
Radio, cd, and hdd work fine. It's just Bluetooth and iPod that has no audio. The ip bus cables are correct.
The nav looks to be working now. I reset all the calibration and I'm driving on the correct streets now.
