X930bt does not acquire satellites
By easyeatlanta · Dec 25, 2011in Problems/Troubleshooting💬 12 posts👁️ 2,041 views
Posted Dec 25, 2011 · 03:35 UTC#1
Just installed a x930bt in my truck and cannot acquire any satellites I didn't hook up the vss wire but as I have read that only helps in bad reception areas. Any help would be greatly appreciated because im taking a road trip on monday
Posted Dec 25, 2011 · 19:09 UTC#2
The vss will help with GPS accuracy everywhere but doesn't have to do with picking up the GPS signals. I'd get GPS sensor is plugged in fully.
Posted Dec 26, 2011 · 02:38 UTC#3
in the settings it says the gps antenna is ok i took a picture maybe that will help
Edited Dec 26, 2011 by easyeatlanta
Posted Dec 26, 2011 · 02:43 UTC#4
Posted Dec 26, 2011 · 04:32 UTC#5
I'd still confirm the plug is fully seated and where do you have the sensor installed? If it's free try placing it on the outside of the dash or outside the car to confirm that it's working correctly.
Posted Dec 27, 2011 · 02:55 UTC#6
yeah its on my dash but i will try again to reseat the plug was I supposed to activate it or anything?
Posted Dec 28, 2011 · 21:44 UTC#7
I reconnected everything and it still is telling me im in california which is 1800 miles away so its just a little off
Posted Dec 30, 2011 · 00:28 UTC#8
Do you have one of the vehicles that has a metal film in the windshield? GPS can't see through them. Put the GPS puck outside the vehicle attached to a metal base (hood, roof, etc.), park with no roof or garage over you, and give the device maybe 10 minutes for the initialization to take. If it doesn't work then you have a bad GPS puck, bad wiring, or bad head unit.
Posted Dec 30, 2011 · 01:56 UTC#9
my portable gps has no problem with my windshield
Posted Dec 30, 2011 · 17:05 UTC#10
fine, then dont try his trouble shooting steps. good luck finding the problem if you wont rule out possible issues.
but in the end, you either have a bad antenna, a bad avic, or a bad antenna placement.
and no, there is nothing to activate for gps, you simply turn it on, and let it work.
Posted Dec 30, 2011 · 21:49 UTC#11
chill buddy i have already tried what he has said to try thank you very much I was only adding a common sense fact, the first place it was located was on my roof.
Posted Dec 30, 2011 · 23:20 UTC#12
how did you get the wire from outside the car to inside? what are the chances that the antenna wire was damaged?
