Boyo VTK350 and X910BT
By elektrik · Dec 29, 2011in Problems/Troubleshooting💬 7 posts👁️ 2,024 views
Posted Dec 29, 2011 · 20:06 UTC#1
Hello All. I apologize that my first post is a call for help, but unfortunately it is what it is.
I have a 2007 Scion tC and I recently purchased a good used X910bt unit from Ebay. I also purchased a Boyo VTK350 backup camera. I've included the 'manual' that came with the camera here, in the hopes that someone might be able to help me.
I've connected the black to the frame, and the red to constant 12V (mainly because I'm assuming it needs constant power; the documentation doesn't say anything, so I'm assuming it does). I've connected the Yellow cable to the brown input on the unit, but no video.
Any ideas?
Thanks for the awesome site btw (I've already updated my firmware/maps!)
Posted Dec 30, 2011 · 17:14 UTC#2
first off, if the camera is connected to constant power, it will never shut off, and will drain the car battery. reconnect power wire to an acc power source.
second make sure you have a good ground.
make sure you have the reverse wire from the avic connected so the avic knows when to switch to the camera source.
Posted Dec 30, 2011 · 19:27 UTC#3
I *believe* I have it connected to accessory 12v but I'll make certain.
Posted Dec 30, 2011 · 23:23 UTC#4
sorry, this made it sound like it wasn't
regardless, i dont think that is you problem. but it could become another problem.
i would test to see if the problem is the avic not showing the image, or if the camera is not outputting an image.
Posted Jan 01, 2012 · 21:12 UTC#5
So, it turns out that you were right-it was connected to constant 12V, however after switching it to Accessory, it made no difference :(
Posted Jan 02, 2012 · 03:56 UTC#6
that was a totally different problem, it had nothing to do with you orignal issue.
as mentioned above, you need to figure out which device the problem is with.
the easiest way is to substitute different components, for ex: try hooking up a dvd player to the camera input on the avic and see if that video signal ahows up. if it doesnt, they the problem is with the avic. if it does work, then try to hook up the camera to something like a small tv to make sure that the camera is working.
Edited Jan 02, 2012 by 1loudls
Posted Jan 03, 2012 · 21:53 UTC#7
Roger that. Hopefully the backup input itself on the x910bt isn't bad....
