Hello all
I purchased a X390-BT for my Mercedes ML320. I installed it and after about 3 hours of 'fitting' it was in and worked perfectly. I also did the video by-pass and all worked perfect. About 2 weeks ago I decided to add 2 amps and a sub to my car, so I pulled the radio, unplugged everything, installed 3 RCA cables (front, rear, sub), tapped the 'remote power lead' from the X930 wiring harness, and plugged everything back in. Unfortunately all is not well now. I have 3 distinct problems now.
- My Video By-pass does not bypass anymore. I get a screen that says my parking brake wire is not attached correctly and I can not watch video or adjust my Navi while the car is in motion.
- I have a faint 'feedback' sound now that I can hear at low volumes, but can't pinpoint exactly where it is coming from. It is from the stereo system, because it does not feedback until the system boots up.
- Rear-view Camera will not automatically turn on when I place the transmission in reverse. I tested the camera with a small TV and it works when I place the car in reverse. I tapped the back up light for power.
I placed my amps under my front seats, which only ended up being about a 6 foot run for the RCA wires. the smallest RCA cables I could find were 12 footers. Would my feedback I am getting be coming from the excess wires that are neatly wrapped together in a loop and tucked under my center console? I am not really getting any road noise where I hear a whine when I press the accelerator pedal. My main power cable is run close to the RCA's, but i'd say that it is at least a foot apart. the whole feedback thing is something that I have never come across before. I can't say if its technically road noise or not. Anybody out there have any tips or pointers? They would be greatly appreciated.
thanks in advance,
KYJ
