Cranking up the volume mutes the front and rear speakers
By Buckkoo · Jan 03, 2012in Problems/Troubleshooting💬 2 posts👁️ 862 views
Posted Jan 03, 2012 · 18:57 UTC#1
I have a a Z130BT in a 2007 Ford F250 with Alpine speakers and the factory sub woofer. When I turn up the volume loud the unit mutes the Alpines speakers front and rear, but the factory sub woofer continues to play. The only way to get sound back is to turn the unit off and back on ? This problem started right after installing the Alpine speakers. Their polarity is correct and they sound great at lower volume.
Why does the unit mute itself ?
Posted Jan 25, 2012 · 04:29 UTC#2
I bet they're the wrong impedance and the HU is in thermal protect mode. Are the Alpines 2,4, or 8 ohm? Are they in series or parallel? Did it have a factory amp for the main speakers (not just the sub)? Did you hook up front and back to the front only and the sub to the rear? Double check that the total load on each Chanel is not less than 4ohms. That should solve it.
