Can I connect factory installed xm tadio to AVIC-Z1
By GreatRock · May 24, 2006in General💬 6 posts👁️ 1,724 views
Posted May 24, 2006 · 00:56 UTC#1
I am AVIC Z1 user.
But I have already XM radio in my cadillac. Can I use this XM radio to Z1?
Posted May 24, 2006 · 01:06 UTC#2
Short Answer: No
Long Answer: In theory, if you can determine what the audio out and control leads are for the factory xm, you could use it as a Aux input.
Posted May 24, 2006 · 02:11 UTC#3
No you can't, however you can use the factory xm antenna for an aftermarket xm tuner.
Posted May 31, 2006 · 04:43 UTC#4
Will the GM factory antenna work with the xm/nac traffic tuner??
Posted Jun 05, 2006 · 03:06 UTC#5
Yes. Use the yellow lead only.
I've made a little video about it showing detail in my GMC Canyon when I did it last summer (June) when I got the AVIC-D1.
http://web.ics.purdue.edu/~grajkovi/mov ... How-To.wmv
The video shows BOTH wires being used with the GEX-P910XM tuner, however I've since upgraded to the GEX-P10XMT and am only using the YELLOW wire.
Just connect the yellow wire. If your vehicle is different than the one shown then the location of the XM tuner may be different, however the procedure will be the same.
Good luck!
Posted Jun 07, 2006 · 13:30 UTC#6
Thanks for the video!
