Caution: screen image may appear reversed?
By nodnarb901 · Jan 24, 2007in Problems/Troubleshooting💬 15 posts👁️ 49,864 views
Posted Jan 24, 2007 · 12:53 UTC#1
I have had my avic d1 installed for about one week and then last week installed my 60mp update disc. This morning when I started the car I get a Caution: sreen image may appear reversed. Any idea what this is?
Posted Jan 24, 2007 · 15:34 UTC#2
that is for the reverse backup camera. its just telling you that the image could be reversed depending on what camera your using
Posted Jan 24, 2007 · 16:45 UTC#3
I have no camera, how do I get this message to go away?
Posted Jan 24, 2007 · 16:49 UTC#4
where is this message displayed ?
Posted Jan 24, 2007 · 17:38 UTC#5
It comes up immediately after starting the car, after the Pioneer screen goes away and before the navigation disclamer screen when you have to press ok to procede to use the navi. The whole screen is black and in light grey/white lettering at the bottom in the middle it gives me the message.
Posted Jan 24, 2007 · 17:39 UTC#6
BTW; nice car. I drive an stage 2 04 STi.
Posted Jan 24, 2007 · 17:51 UTC#7
in reverse? maybe your reverse got switched? check the reverse setting that has batt or ground. maybe its thinking your in reverse when your not, and when you put it in reverse it thinks your normal.. is that what is happening?
Posted Jan 24, 2007 · 18:00 UTC#8
I don't think so. Everything else is working fine on my navigation, tracks accurate, etc....
once I get past that screen it doesn't come up any more.
Posted Jan 24, 2007 · 18:06 UTC#9
No it doesn't happen when i leave in in reverse. I start the car, pioneer screen comes up, then the caution: screen image may be reveresed. then the pioneer navigation warning screen comes up, I press OK. then goes into the navigation just like normal.
Posted Jan 24, 2007 · 18:31 UTC#10
check the reverse camera setting
Posted Jan 24, 2007 · 18:35 UTC#11
Thanks for your help with this. What should the reverse camera setting say? I assume you mean in the connection screen.
Posted Jan 24, 2007 · 18:37 UTC#12
in the setup screen, maybe even initial, i dont recall, there is a setting that tells the d series what polarity the reverse is. try changing it and see if the problem exists still
Posted Jan 24, 2007 · 18:43 UTC#13
If you don't have a backup camera, you should never see that screen. Go into your setup menu, and turn off the camera input.
Posted Jan 25, 2007 · 12:52 UTC#14
Went out to my car yesterday afternoon and turned off the camera input. took care of my problem. guess I accidently turned it on.
Thanks for the help.
Posted Aug 04, 2012 · 11:40 UTC#15
I jus bought one n mine was doing it but on the home button when u cango to reverse camera it was turned on i turned it off been fine ever since
