I have been trying to fix this problem for over two weeks. I have installed and uninstalled just about everything.
The unit boots to the pioneer logo screen goes black for a second and then the pioneer screen comes back on it stays like this for about 5 min and then reboots and repeats. I have the unit out of the car with no sat nav antanna pluged in and only the power wires connected to a power supply. I live in Australia and the unit is American when I boot using a test disk the propertys of the unit in WinCE says that it is a F910 and not a X910. When I boot into the service mode where you install the winceimg I do not have to use any of the key press' (up up down menu left right)
I do not get the first screen with the av, satnav, etc icons, I can use some of these in windows ce but they don't all work properly. Is it possable to get a copy of the My Flash Disk folder structure this might help me to see if I have all the right files in there.
I have used this file FX3.1without maps dem poi buld.rar that I downloaded when I get it to load it says that no language files were found I correct that and try again it installs but still hangs at the pioneer logo.
Any help would be appreciated.
Just to add some more info I can run the programs that in the folder APL if I go into the windows ce mode
