AVIC-N2 Screen getting stuck !
By pcguy760 · Jan 24, 2007in Problems/Troubleshooting💬 5 posts👁️ 2,670 views
Posted Jan 24, 2007 · 13:30 UTC#1
Hi,
My N2 was working just fine until yesterday when I tried to open the screen and it only came out about an inch and just stayed like that! So I gently pulled it out a little bit more and pressed the OPEN/CLOSE button - it came out all the way and worked fine.
So I try to close it after that and it did the same thing - it folded down correctly but went into the headunit with about an inch sticking out!
Any ideas what the problem might be? Do you guys suspect that it might be the ribbon cable that Pioneer is now replacing?? Did not send mine in yet ...
Thanks Guys!
Posted Jan 24, 2007 · 15:31 UTC#2
the cable they are replacing is for the n series I believe. But that isnt suppose to be for the movement its the video on screen that is the problem. Is there any obstructions? maybe something internal if not.
Posted Jan 24, 2007 · 18:47 UTC#3
Yeah, the ribbon cable repair is to fix the screen going black or touch not responding. It sounds like you have an internal mechanism problem, which is not unlikely, since most of the gear drive for the screen is plastic.
Posted Jan 26, 2007 · 08:41 UTC#4
Okay thanx - I guess I will see what I can do about that ...
Posted Feb 11, 2007 · 15:34 UTC#5
Well not to prove you guys wrong or anything but I went ahead and sent the unit to Pioneer and come to find out, it was NOT a mechanical problem but the flex cable doing that! It makes sense now to me because I did notice that the flex cable is the only cable going to the screen which means it does control the motors on the screen assembly as well.
Well anyways, I must compliment Pioneer on their very fast and professional manner in which they handled my flex cable upgrade. They also cleaned the unit, because I noticed the screen was spotless when I got it back (my fingerprints were all over it when I sent it in, but it was broken so I did not care much lol). Also I noticed the gear assembly is much quieter now.
Well that's my 2c on this. My N2 is up and running just great now :)
