My Z110 is still in the box, (long story) I was planning on doing the updates to get it in line with the Z130 and its updated maps etc. How can I go about finding out which is installed? If iit has 1.001 or 2.003,so I can figure out if I am able to update straight to the USCNSD 210 or if I have to go through the longer process of updating to 120 and then to the 130 and the 210. Sorry if my termonology is wrong.
Figuring out which Z110 upgrade is installed
You don't have to do incremental updates or upgrades. Just go straight to the upgrade that you want.
Kind of what I was thinking. Thanks, makesit a lot easier. So I can go from the base 110 to the 130 with the hacked 2.00400? then the cnsd210?
No, install the 1.002 based ShortFuse hack. That will defeat the password validation for the next upgrade. Now install CNSD-210FM. You can't install 2.003 unless you've already installed 2.0 (CNSD-110FM).
BTW, going from 1.x to 3.x, after installing the upgrade - you should install the BT from CNSD-210FM SD1 first, then again from SD2.
BTW, going from 1.x to 3.x, you should install the BT from CNSD-210FM SD1 first, then again from SD2.
Thanks for the info. Did some more reading and that is what I thought was needed but so many different problems posted it is hard to tell which applies sometimes.
Download the v1.001 update from Pioneer.
Replace AVICZ110EU090APL.VER and AVICZ110APLRenewalIFLib.dll with the files attached.
I don't see the file renewallFLib.dll the 1.001 folder. Has the APL.VER though
Nevermind
did some digging and found it.
