F30bt into Audi RS4
By Rick_RS4 · Feb 02, 2012in General💬 9 posts👁️ 1,868 views
Posted Feb 02, 2012 · 20:57 UTC#1
hi, i have factory sat nav Rns-e which i hate, so i was thinking of upgrading to the f30bt, i have a few questions.
i want it to be as factory as poss, is there anything that might not look factory?
can i hide the antenna? or use the audi one?
it says it can be used with the vw canbus parking sensors and heated seats, i have these in my audi will it work?
is it a good unit, should i be looking at something else?
can you get a decent tv tuner
on my screen at the min on startup it says RS4 can this be done also?
thanks
Posted Feb 02, 2012 · 20:59 UTC#2
how do you upgrade the maps? ie new roads etc?
Posted Feb 02, 2012 · 21:19 UTC#3
oh and will it work with the factory bose amp and speakers?
Posted Feb 03, 2012 · 17:03 UTC#4
anyone?
Posted Feb 03, 2012 · 20:41 UTC#5
thanks
You can usually use the factory antennas, I did on my VW (after removing the proprietary connection).
When you say parking sensors, do you mean a backup camera?
The radio isn't going to effect heated seats...
TV tuners don't work very well in a moving vehicle.
Yes, you can make the startup screen any .jpg you want.
SD Card
Should, with the correct adaptor.
Posted Feb 04, 2012 · 14:12 UTC#6
In my previous car a Audi A4 2.0T Quattro I had the RNS-E with telephone blue tooth function. Today I drive a Mitsubishi Outlander with a Pioneer Avic F30BT which I installed by myself see my thread at
http://mitsubishifor...question-41409/ I think I can compare the RNS-E with The F30Bt because I have used them booth. If I owned a Audi today I would stick with the RNS-E because I think it fits the car better (looks better) than an F30BT would. The RNS-E is a very good unit and easy to navigate. If you are going to install a Pioneer Avic F30BT you should be a rather technical person, you have to by the right harness (adaptors), probably even a steering wheel controller, new mic placment and so on. I don't think you would perform an "upgrade" with the Pioneer F30BT it would be just a step sideways. The Pioneer have worse speak recognition than the RNS-E, the maps looks about the same as the RNS-E, SD-card plays the same extensions (mp3, no flac, no avi) in booth units, but the Pioneer can have larger SD-card than the RNS-E support. The only thing the Pioneer do better is that its playing DVD (but who cares, if it played mkv, DivX it would be better) and has Auto EQ calibration wich is rather cool and useful.
You do what you want, but I sometimes miss my RNS-E and I would keep it if I had an Audi.
Edited Feb 04, 2012 by chavabunga
Posted Feb 04, 2012 · 18:18 UTC#7
thanks for your replys, i was going to upgrade because the rnse only has 5 digit sat nav, no bluetooth, thats like 300 pounds more no aux in, but thanks for your honest opinion, i think ill just leave it,
and remember dont fix it unless its not broken
Posted Feb 04, 2012 · 18:56 UTC#8
I bought my blue tooth for the RNS-E afterwards and install it myself in my Audi, maybe something you could think about. Not so expensive if you would like to have the phone ability.
Posted Feb 04, 2012 · 20:57 UTC#9
i just like gadgets, i think ill do as you say and try it for a while, also im running a 2007 disk so could be better with a 2011 disk
