So the other day i downloaded the torrent to ugrade my z110bt to the z130bt software. i put the software on the sd card and everything was going smooth then, while it was on 27% of the update. It failed. Now whenever i put my unit on it just says Wrong Sd card. Please insert correct sd card. What do i do please somebody help. Im willing to pay somebody for help on my unit.
Z110bt Unresponsive
First, you need to eject that SD. Turn on your ignition while pressing and holding the Eject button. It takes a few seconds.
Your next problem is a bad SD. Get a new 4GB SD, format it FAT32.
Wait. Before you install again, what other things did you do? You can't just install the torrent CNSD-210FM without some prep work - installing the ShortFuse hack onto your Z110. Did you do that? If not, you've got some reading to do.
Yea I've done all the necessary prep work I've updated quite a few z110s and z120s but this is the first time I encountered an error saying incorrect. Wrong sd please insert the correct one. I'm just lost my radio will not do anything.
I tried a new sd card. I tried 2010 maps and 2011 maps. I looked all over for how to do a mater reset I couldn't find anything
