I have an issue with my X910BT where the sound will cut out somewhat randomly. I have audio running from the RCA front and rear outputs to my factory amps. I first thought my factory amps were going bad so I bought a line output converter to test and the sound is stable (doesn't cut out) when ran through the LOC but the quality is pretty poor. I next thought that it might be the RCA output harness that had a wire going bad but I also replaced that and it's still cutting out randomly. I've checked all of my wiring and it's definitely good. Has anyone else experiencing a problem like this? It is almost as if the soldering is coming loose on the connectors where the harness plugs in as if I move the wires around a bit on the RCA harness, sound will come back. Same type of thing happens if I hit a bump.
I've done some reflowing of solder previously but I am not sure I want to try to take apart my unit to try to solve the problem as I have no clue what they are like internally. Anyone have any suggestions for me?
