Update to use newer versions of bluetooth???
By thunder92 · Feb 07, 2012in Hacks/Mods💬 10 posts👁️ 7,158 views
Posted Feb 07, 2012 · 17:12 UTC#1
I assume this has been discussed but I can't find it anywhere on here. I have heard that a update may enable use of newer versions of bluetooth on the avic-d3. My new droid razr won't work. My old droid x barely did.
True, not true? Link to the update is possible?
Thanks, so much.
I'll have to post of pic of y custom install of mine. My truck only had a single din spot before.
Posted Feb 10, 2012 · 13:20 UTC#2
I am having the same problem. I just upgraded my Galaxy Nexus to Android 4.04 from 4.02 and now it won’t let me pair my F700BT unit. The phone asks for the pair code but says it’s the wrong code when I enter in “1111â€. Does anyone have any solutions to this situation?
Posted Feb 10, 2012 · 18:27 UTC#3
Join the club Benji. Wish I could figure it out. Maybe I'll try and call pioneer.
Posted Feb 12, 2012 · 19:37 UTC#4
OK this is very easy, pioneer has make an upgrade for any bluetooth problems, download first version 3 driver http://www.pioneer.eu/eur/support/software/AVIC-F700BT/index.html !! Unzip file to SD card and put the 3 files in the root of the SD card not in a map.
· Press “Phone†and “Phone Settings†in the main menu to open Phone Settings menu.
· Put the SD-card which contains the update files into the unit
· Make sure “Bluetooth On/Off†is set to “Onâ€.
· Scroll down the menu by pressing the downward arrow on the left.
· Select "Bluetooth Software Update"
· Press “Software Update†button on screen to start updating.
· Update takes about 3 minutes.
Kind regards !! 8)
Posted Feb 28, 2012 · 04:41 UTC#5
the hell unit are you talking about, there's no SD slot on the D3...
Posted Feb 28, 2012 · 08:27 UTC#6
There will be no newer bluetooth updates for this unit.
Posted Aug 16, 2012 · 19:10 UTC#7
My Blackberry hardly worked, however my Iphone works and the code is"0000". I do have to connect manually each time I get in the truck or after I turn the key off.
Posted Aug 26, 2012 · 20:13 UTC#8
my blackberry 9900 works like a charm. never have a problem during calls and connects everytime
Posted Mar 02, 2013 · 03:25 UTC#9
Can't get my droid bionic to work. Do I need an adapter? The manual reads like sh@t! Also can't get my clock to set. Help!!!!! I just got this and already want to get rid of it.
Posted Jun 12, 2013 · 07:15 UTC#10
I've never been able to get any phone to work with the stupid bluetooth box. so frustrating. ..
-Nigel
