Error updating AVIC-F900BT
By zentral · Feb 10, 2012in Hacks/Mods💬 6 posts👁️ 2,179 views
Posted Feb 10, 2012 · 19:55 UTC#1
Hi everybody,
this is my last chance
Well my history start when i bought an AVIC-F900BT device, i put my device on storage for a many reasons for two years, well, i lets go to car workshop and i try to mount it, but tell me that i need some parts.
This car workshop start the unit for verify and configure without any idea.
Well now i need to update the unit but in settings appear disabled 2 of 4 options, i can only change sound av and config av.
i think that my unit is not updated to 100 or 200 firmware.
download the firmware from pioneer, insert into sd and unit doesn't boot.
if i press the reset button for 5 or 10 seconds, the unit starts correctly, and the other options from the factory restore settings is disabled the menu.
Can anybody help me???
Thanks in advance
Posted Feb 10, 2012 · 21:58 UTC#2
well an update:
i delete the folder setup from my flash driver -- user data -- user with testmode
reboot the unit and appear the language selecction, but i cannot select spanish language or other, appear disabled, when i press ok the nest screen is voice language and only can select ok.
any idea
Posted Feb 15, 2012 · 18:11 UTC#3
anybody can help me please.
Thanks in advance
Posted Feb 24, 2012 · 06:13 UTC#4
have you connected you parking brake cable?
Posted Feb 26, 2012 · 18:54 UTC#5
spiceweasel, thanks for your post, well no i can play videos too, and all option are now ok, i use a tutorial found on youtube, with search text "bypass F900BT", now i need the sd "A" from cnsd-300FM. anybody know where i can find???
Posted Feb 27, 2012 · 09:37 UTC#6
just connect the parking brake cable to the ground of your radio..
the cnsd-300 fm doesnt help you because it must be activated online with a special code on the pioneer website.
first make a complete backup
then you can play with different versions avaliable like fx 3.1 oder the hybrid version 4 and add newer maps
