AppRadio Extensions v1.1.0 is out on Cydia. I added full support for iOS 5 and the ability to bypass the alert that pops up when you plug in your phone or press on the Apps button. If you have any issues, post them here and I'll try to help.
AppRadio Extensions v1.1.0 update available
Thanks!!
Cool!!
thankssssssssssss a lot ![]()
I dont know if its just me but. After installing and using appradio extension I was not able to download any apps from the app store. I removed the appradio extension and I could download apps again.
Anyone else have this problem.
Disable the alert bypass for now. I already submitted a fix to the repo.
Launch video is gone, still get standard "don't use when driving" prompt and the "apply / ignore" prompt.
Is this what got put back because of the bug?
PS-Mike, thanks for this app, it makes all the difference in the usefulness of this product.
Alright will try again. Thanks.
I started out with 2.22 and AppRadio extensions after iOS5. Even though iOS5 broke much of the app ext it still worked pretty good for me. I updated to 2.45, and it broke more of app ext, but I would say it seemed faster. Yesterday I upgraded to 2.22 AppRadio +. It did all as advertized, makes all warnings disappear, but it looks buggy and at times other screens come up and at this point is not fully translated into English. I think it's a great start, but needs some fine tuning. This morning I went back to Pioneer 2.22 and updated to the latest AppRadio Extensions, I must say this is by far the cleanest solution to date. I see some people have found some bugs and im sure Mike will get them fixed quickly. Some observations:
Warning screens show up as apps are loading, but once the app is loaded they disappear. So have a little patience.
It takes a while for the iPhone to connect to Bluetooth. Again need a little patience. You can disconnect your phone and Bluetooth still works.
My relay parking brake bypass is working great.
I do not like the AppRadio phonebook, you can not scroll by letters. I find this aggravating and dangerous.
I don't like the contacts for phone use much either. If you use this to call someone it delays quite a while before it indicates you're connected, meanwhile the person on the other end is wondering what's going on.
In addition to AppRadio Extensions, I have Handsfree, voice activator, and activator loaded. Between all of theses I can talk to my iphone and get it to load apps Handsfree, works pretty slick
Overall we are closer no thanks to Pioneer!
The update is in Cydia now. Everyone should make sure they are on version 1.1.1.
No, make sure the bypass is set to Accept in the preferences.
What problems were you having with 2.45? So far I haven't had any issues with the latest firmware. I'm still not able to make phone calls due to the microphone being too low, but that has been a problem on all versions.
I haven't tried 2.45 with your updated AppRadio Extensions. From the various posts everyone pointed to using 2.22. Is your update good for 2.45 and should I try it. When I had it and before your update it would not let me into the apps section, I could not get past a warning.
By the way I placed my mic on the window sill, it's about 12" from my mouth and works very well. In the AppRadio utilities screen if you go to general settings, there is an icon on the far right, looks like 3 bars. If you click on this, there are 3 options. One is for Handsfree and one is for iPhone. I have adjusted these up to a setting of 2. Everyone has told me they can hear me really good now.
Still not works for me 2.45 with DisplayOut
Anyone else having issues with the SiriusXM app? I can't imagine the two are related, but since AppRadio Extensions is the only thing I've installed lately, I figured I'd mentioned it here. Beginning this morning I get the "You are Logged in Elsewhere" warning in the SiriusXM app approx every 4-5 minutes. My first thought was my password got hacked or something, so I went to the website and changed the password, but it's still occurring.
Oh and is anyone else not getting notifications?
I get the standard "4:34pm text from" pop up but not the actual text like I did with the last version.
Same applies to notifications
What verison of the OS? If IOS 5, is it an actual popup or the thing that appears at the top of the screen and then goes away?
Hey Mike, iOS 5.01, 2.45 on radio. Before I upgraded to 5.0 I got the message across the top, now I get a popup bubble in the middle with just the time and sender.
I assume you are talking about the popup bubble that displays on the radio? Are you in the iPod or one of the other supported apps? The notifications only show up in the other apps.
I think just showing the time and sender may be a setting in the preferences. Under Notifications, look for Messages and see if 'Show Preview' is enabled.
So yesterday during my commute I was in the iPod (hence just the bubble) but today was listening to Pandora, got 2 texts and an app notification and they were visible as notification bars at the top of the phone but nothing came across to the radio.
For what it's worth I've got the SBsettings dashboard installed, including an app that pushes music info As a notification bar.
Oh and I've got texts and notifications set to notification bar instead of alerts.
Could either of these be causing issues?
Notifications won't show in Pandora at the moment. I'll have to add that to the documentation somewhere. When Pandora starts on the phone, it actually tells the radio to start a built in Pandora application. So what your seeing on the radio isn't the iPhone display. Since it's not the actual iPhone app showing, I can't display notifications over it. It's on the todo list.
I had some interesting things happen today with app radio.
In the main window (radio /ipod /apps /phone). If im in ipod i get a pop up saying text message from without the message which is kewl and has been doing this since day one.
But today while using the pioneer app radio app and running any app that would work with it. I was able to get a text message at the top of the screen with persons name and the whole message.
I found this to be very handy.
