Cant find VSS or backup wire
By word2yamutha · Feb 11, 2012in Problems/Troubleshooting💬 4 posts👁️ 1,062 views
Posted Feb 11, 2012 · 22:52 UTC#2
Could always tap into the reverse lights.
Posted Feb 24, 2012 · 22:40 UTC#3
i would get power from the camera from the acc wire at the radio, then you can get the reverse trigger wire from the reverse light bulb at the back of the car. that way you could always use the camera when not in reverse if you wanted too.
Posted Feb 24, 2012 · 22:48 UTC#4
and according to directechs, the VSS wire is gray/orange or gray located at either the data link connector, 16 pin plug, pin 6 or at the BCM, white 20 pin connector, pin 6
(The BCM (Body Control Module) is in the center dash, behind the A/C controls. The data link connector is under the driver dash.)
it also says that the reverse wire is gray or brown, located either in the drivers kick panel or back of the fuse box, 30pin plug, pin 13 or 14.
as always, test all wires with a DMM, not a test light!
