Iphone case that works with the Pioneer Cable.
By Maguinee · Feb 12, 2012in General💬 10 posts👁️ 1,757 views
Posted Feb 12, 2012 · 22:40 UTC#1
I apologize if this has been covered before. I have done several searches and have not found anything in forums that address this so I'm posting a new question.
I have an iPhone 4 with an "incase" two piece phone case. I have the Z130BT with the Pioneer Cable and the cable does not fit through the charging port on the case.
Currently I have to remove the lower half of the case to hook the cable up. Not the worst thing in the world but would prefer not to have to.
I could drill out the slot on the case but my case is old and I'm looking to replace it anyways. I could also trim down the plastic on the cable's connector but really don't want to to do that with a $60 cable. My luck I'll ruin the cable.
Does anyone have a case that is compatible with that cable?
Posted Feb 12, 2012 · 23:59 UTC#2
Had that problem with my iTouch case. I just used a hand file and enlarged the hole for the connector. Don't remember what brand the case was - just a cheap case.
Edited Feb 13, 2012 by RonS
Posted Feb 13, 2012 · 00:52 UTC#3
RonS
Thanks! Since I care far less about my case than the cable I decided to take your advice and try to file my case out. I used a round rattail file and it worked like charm.
I am still looking for other case options as I want to replace my case anyways. At this point if nobody knows of another option then I will buy another "incase" and reuse the bottom portion that I filed out.
I appreiate your response Ron!
Maguinee
Posted Feb 13, 2012 · 01:09 UTC#4
I've got a Belkin Folio leather and it's no problem with the cable
Posted Feb 13, 2012 · 02:16 UTC#5
Thanks zx6rrdan
I'll have to take a look at that one. Not sure the wallet style is what I'm looking for but I'm open to looking at anything.
maguinee
Posted Feb 15, 2012 · 01:53 UTC#6
Have both the incipio double cover and the otterbox commuter case. Both work well with the pioneer cable. Btw i have iphone 4s.
Posted Feb 19, 2012 · 16:00 UTC#8
Thanks for the additional info.
Raider - I took a look at the cases and right now the front runner is the Otterbox. Looking more at the defender than commuter mainly because of the camo option. Any reason that you are aware of that I shouldn't do that?
Dentauthority - Thanks to you as well. I have ordered one of those adapters and am looking forward to it. I've never seen anything like that.
Maguinee
Posted Feb 21, 2012 · 13:12 UTC#9
I use an Otterbox Defender case for my Iphone 4. Works very well with the Pioneer cable. No issues whatsoever.
Posted Feb 21, 2012 · 20:13 UTC#10
I just didn't like the bulk of the defender. The commuter is a little slimmer as it doesnt have the built in screen protector.
