AVIC Z1 with Z3 drive.
By ddomingu1976 · Feb 15, 2012in Problems/Troubleshooting💬 3 posts👁️ 1,240 views
Posted Feb 15, 2012 · 18:36 UTC#1
I just updated my Z1 to Z3 with a new drive. Here are the versions I get:
Version 05.0000
CDDB 10-01-0010
Platform 3.000200
GPS Program Version 1.200000
HDD Application Version 5.000000
Am I set with the above versions for the "2 wire" bypass or do I need to upgrade any of the above? Once the car starts moving it kicks me out of all unlocked features. I read through some of the posts and it said it is probably the bottom right yellow wire is not grounded, but I want to know if I need a firmware update first before I start tearing the radio out.
Posted Feb 15, 2012 · 18:52 UTC#2
Your firmware is fine and fully supports the 2 wire bypass. correct your wires, press the reset button and you should be good to go.
Posted Mar 15, 2012 · 14:33 UTC#3
hey my name is freddie i also have da same problem i have the avic z1 n its doing the same thing it freez, n reboots i will like to upgrade it to da z3 i heard i can b done i dont know much about how to go about it... can some1 help me....... u can reach me @ 917-405-0980 i am in orlando,fl
