Hello everyone, I posted a while ago about my D2 not producing sound for no reason and I sent it for repair and it was repaired and i am soo happy. I missed it soo much.
This post os to confirm everything ive done is correct and there isnt something that made my unit's audio output fry.
My Bypass is perfecto i guess. I ground the parking brake wire, and the extra pin. And the bypass worked fine. I am installed new 5 1/4 MTX speakers in the front door the same day that my unit went off.
My unit came with a tag sayig as follows:
Grounding Problems and Resolution
- This unit was recieved with open or burned PC board ground traces
- The most common cause for this failure is undersized wiring or loss of connection of external grounding wires
- check manual for all grounding for item before reinstalling.
If someone could give me an insight if there is something wrong in my setup or what to look for. I am not looking forward to have the same problem again and send my item for another 2 and a half week adventure for repair.
Thank you very much for your time.
