Sorry for all the post. I was wondering if someone could help me out here with my nav? My location stays in one place and never moves, how can i fix this? Thanks
Nav location not working, need help
Check the antenna under connection status.
No barsCheck the antenna under connection status.
2 bars and still not working
When i do get bars, the arrow shows us going backwards. Id like to get it working right.
Ok. I figured it out on my own. Thanks
Thanks. I had to go in and recalibrateCheck the antenna under connection status.
We just took a little trip and my gps not doing to good. We got to our turn and gps wanted us to keep straight into the ocean and it kept freezing and it pissed me off and ready to get rid of it unless i can figure out whats going on and how to fix it.
There's obviously an issue with the antenna, where it's mounted, or both.
Its on the dash. It was working good until we got near the oceanThere's obviously an issue with the antenna, where it's mounted, or both.
Is VSS connected?
You think that has something to do with it? I had a few bars for the signal until we got to the beach and had noneIs VSS connected?
VSS takes over when there is no or poor signal, so yes.
Ok, i'll try to find out how to hook it up or try to find the wire so i can hook it up. ThanksVSS takes over when there is no or poor signal, so yes.
If it dosnt work after i find and hook up the vss wire, i guess i'll buy another antenna for it cuz its not the antenna that comes with the d3, its an ebay one.
