Need F900BT "myflashdisk" files
By Reborn996 · Feb 26, 2012in Hacks/Mods💬 8 posts👁️ 4,631 views
Posted Feb 26, 2012 · 23:39 UTC#1
Hi everyone, it turns out I mistakenly flashed my friends F900BT with the SD mod hack for my 9115BT...which corrupted the unit. I used the firmware downloads from Pioneer but they are not a complete image of the "My Flash disk" folder. Does anyone have a copy of this folder content they could send me so we can try to recover this unit? We need the complete contents for the folder...
The backup we did apparently did not work either. :(
Help????
David G
Posted Apr 11, 2012 · 18:22 UTC#2
try using the FX3.1 firmware. it worked for me.
Posted Apr 11, 2012 · 18:44 UTC#3
it also comes with test mode
Posted Apr 22, 2012 · 08:18 UTC#4
I have a f900bt 'myflash disk ' files I could upload for you somewhere if needed still.
Approx 1.5gb unzipped.
Edited Apr 22, 2012 by cleverdicky
Posted Jul 07, 2013 · 06:21 UTC#5
 Hi do you still have the f900bt "my flash disk" file. i need it
Posted Jul 07, 2013 · 23:34 UTC#6
^^ keep in mind that the way these units work, the AVIC "OS" (if you want to call it that) (not the underline CE OS/ROM)
is the files on the "My Flash Disk"
this means that depending on what you want, you may run the 2.x OS, the 3.x OS or the 4.x OS
so now the question is what do you want, & why do you think you need the whole thing? if your unit not working?
Posted Oct 12, 2015 · 01:42 UTC#7
Do you still have the f900bt "my flash disk" file. i need it. You can email me at [email protected].
Posted Jan 24, 2020 · 23:47 UTC#8
Todavía tiene el archivo "mi flash disck" lo necesito
