Z1 dimmer not working with 08 ford Taurus
By Wilifordmj · Feb 29, 2012in Problems/Troubleshooting💬 8 posts👁️ 1,430 views
Posted Feb 29, 2012 · 04:28 UTC#1
The strange thing is there are two dimmer wires on my aftermarket wiring harness, orange/blk and orange/white. Is there another place where I can connect the z1's dimmer wire.
On another note, apparently the 08 Taurus has no speed pulse wire thingy, I'm new to this, is this necessary to be connected, if so what options do I have??
Posted Feb 29, 2012 · 07:45 UTC#2
Neither one of the dimmer wires supply 12v when the lights are on? If not, any circuit that gets power when the lights are on will work.
Every modern car has a speed pulse, it's just that some are easier to get to than others, sometimes you have to go all the way to the ECU. The Mustang speed pulse is at the ECU for example.
Speed pulse isn't needed if you always have good gps signal, don't drive in tunnels, etc.
Posted Feb 29, 2012 · 16:47 UTC#3
Well I read on a forum just can't find it, that the 08 ford Taurus along with the ford five hundred don't have a vss pulse wire?? And that I must get a can bus interface circuit, I think that's what its called, so my navi can only detect the speed Via gps??http://www.soundlabsgroup.com.au/p/CANBUS-CBSI/CANBUS+Speed+Interface
Edited Feb 29, 2012 by Wilifordmj
Posted Feb 29, 2012 · 18:56 UTC#4
The canbus adapter would also have the illumimation wire to connect to the AVIC.
Posted Mar 01, 2012 · 12:29 UTC#6
For that price I'm good with the gps it's close enough!!
Posted Mar 02, 2012 · 13:17 UTC#7
Update frequency of the display will be much higher with speedpulse (Vss) connected, system will also react more timely to turnoffs etc, and work beter in city canyons (in between high buildings), where GPS reception is problematic....
Posted Mar 02, 2012 · 17:12 UTC#8
well if I could find the wire I would but no luck and im not dropping that kinda cash
