z110bt draining battery please help asap!!!!
By ghost911 · Feb 29, 2012in Problems/Troubleshooting💬 5 posts👁️ 1,203 views
Posted Feb 29, 2012 · 22:12 UTC#1
MY z110bt is draining my battery when my car is off. and i know its tht for a fact.
because:
- took everything off the battery " it died still"
- checked the alternator and its bran new
- battery is bran new yellow top checked okay
- took it to the dealership and they diagnozed it and everything is a okay.
so my issue is why is my z110bt draining my battery? how do i fix this? is the fuse maybe shot and thats the reason? or bare wirres are showing and need to be taped with wire tape?
please help asap i cant keep dealing with this issues any longer. thanks :)
Posted Feb 29, 2012 · 22:26 UTC#2
Did this just start happening? If you just installed it, double check the ignition and constant power wiring.
Posted Feb 29, 2012 · 22:57 UTC#3
ya just started happening.. few months now... and nothing is on the batter execpt for the termanals
Posted Mar 02, 2012 · 19:01 UTC#4
i would uninstall the radio and see what happends. if the battery does not drain then you know you radio has a problem. i have never heard of something like this before but it might be a bad radio. do you have an amp? make sure the amp is not always on. make sure those cables are connected correctly too. good luck. i hope it is not your radio.
Posted Mar 02, 2012 · 23:32 UTC#5
Who did the install? Take it back and make them fix it.
