Hi all,
I can confirm that the iPhone 3GS does work with the AppRadio 1 (SPH-DA01). My device is running 6.1 with AppRadio Extensions beta 2.0.1-450. The trick is to install another tweak called Resupported to enable the video signal to be sent to the AppRadio.
I'm still testing this but so far almost everything works great (GPS apps, compatible & non compatible apps) except for one issue that I'm trying to work on. When in mirror mode the 3GS screen is centered and doesn't fill the screen (appears to only be using about half of the available screen resolution). I presume this is because the 3GS has a landscape screen resolution of 480x320 and the AppRadio's screen is 840x480. I'm curious if there is way to manually specify the output resolution for mirroring.
Mike, which tweak are you using for Video Out? Any insight would be helpful. Thanks for breathing new life into this otherwise useless head unit.
-M
