Blue Reset Screen
By RushMoore · Mar 06, 2012in Problems/Troubleshooting💬 3 posts👁️ 1,117 views
Posted Mar 06, 2012 · 02:43 UTC#1
Hi. I have 2 F700BT units, one in my wife's car and one in my truck. I have had both for over 2 years and have found that they are basically bricks that sometimes malfunction and become fully working navigation units. I have gotten quite good at re-loading the software. In fact, I have a dedicated SD card with the files I need that is ready to go.
A couple of weeks ago, the unit in my wife's car started doing the famous AVIC perpetual splash screen reboot. I was slow in getting it fixed and this morning it started doing something I have never seen before. When it starts, it doesn't even go to the splash screen, it goes straight to the reset screen. So I think that's perfect because I won't have to hold all four buttons to get it to the same screen. When I start to enter the service code, the screen will go blank each time I make an input. If I hold the knob in the up position, I get the asterisk at the bottom of the screen until I let go and then the screen goes blank for a couple of seconds. When it comes back to the blue reset screen, the asterisk is gone. So I can never enter the code. I get the same result with the four button reset as well. I've checked the wiring and all the voltages. All is well there.
I can't get it to go to test mode either with the SD card installed. I even erased the SD card and reinstalled the files on it. No luck. I have taken the thing apart to see if I can figure out if I can replace the flash drive, but I can't without replacing the navi board for a few hundred bucks. Before I buy a factory radio off eBay and use this AVIC for target practice, I figured I'd ask if anyone here has experienced this and whether they were able to fix it.
Any thoughts?
Posted Mar 06, 2012 · 18:51 UTC#2
sounds like you are not doing the procedure just right...
try this:
update (flash OS):
  • insert sdcard in unit
  • to enter uboot mode, flash new OS (winceimg.bin), and format My Flash Disk:
  • power up while holding reset, eject, menu, & map
  • release reset, but keep holding eject, menu, & map
  • at blue screen "please push reset key again":
  • enter sequence: up, up, down, menu, left, right
  • choose "0=WINCE Upgrade"
  • choose "0=WINCE by SD/MMC (Format)"
  • leave sdcard inserted
  • hold reset for 5 seconds
Posted Mar 09, 2012 · 00:55 UTC#3
Thanks for the response.
I thought for a second that I may have been doing something incorrectly. So I got in my truck, put the SD card in, powered up while pressing the 4 buttons, got the blue screen and then entered the service code. I then got the menu. However, in the car, I cannot enter the service code. The screen flashed every time I try to enter a character. When it comes back, the previous character is gone.
