AVIC F700BT USB cable pinout
By ginnnts · Mar 07, 2012in General💬 3 posts👁️ 2,616 views
Posted Mar 07, 2012 · 20:25 UTC#1
Hi everyone!
So my friend tore off USB cable from F700bt head unit while removing it to connect amp wires!
I took HU apart and found the connector, but there are five pins on it and they are not marked so i don't how to correctly solder USB cable back... Because he lost the original cable, i have to use cut off USB cable extender!
Maybe someone knows what is the right order of wires? Some photos maybe?
four wires of USB are +5V, D+, D-, Ground, but which pins do they connect to?
And what is the fifth pin? could it be just shielding or second ground?
P.S. Sorry my English isn't good!
Posted Mar 08, 2012 · 06:09 UTC#2
from the service manual... (pioneer_avic-f700_7010bt_[ET].pdf)
you might be able to get it for free from elektrotanya
Posted Mar 08, 2012 · 06:38 UTC#3
Thanks! Great service manual!
So it seems that pinout is
1. +5V
2. D-
3. D+
4. not used
5. Ground
But in my photo you can clearly see that 4th pin had something welded to it... but in service manual it hasn't!
What could it be?
