Fluctuating GPS Signal (F90BT)
By scoobasteve · Mar 12, 2012in Problems/Troubleshooting💬 1 posts👁️ 588 views
Posted Mar 12, 2012 · 15:11 UTC#1
Hi Guys,
Did a search, couldn't come up with any solutions to my issue, so i figured i'd ask if anybody else has experienced it.
I have a F90 BT, currently Running hybrid 4.0001, 2011 Q3 Maps and Diafta hybrid mods, I just upgraded and installed all of this last night hoping it would fix my problem.
My F90 keeps freezing up, usually 20-30 minutes into a drive, sometimes earlier. It doesn't matter what source its on, (usually IPOD) I tried with FM, and it still froze.
I had this problem when i was running the Factory 3.1 upgrade, with 2009 maps as well. This issue has only started within a few months.
so today, on my drive to work, i decided to leave it on the GPS signal screen and noticed some pretty heavy fluctuations from Excellent signal to poor. Eventually the unit would just lock up. No screen or button inputs would work until restarted.
I've tried moving around my gps antenna, using different ipods, sources etc. to no avail. I should mention that it worked perfectly fine for over a year, with my GPS antenna inside the car, on the rear deck.
Any help would be appreciated.
