Audio delay.
By ylwshakr · Mar 12, 2012in Problems/Troubleshooting💬 4 posts👁️ 1,200 views
Posted Mar 12, 2012 · 19:53 UTC#1
I have the X930BT installed in a 2003 Suburban. Everything has worked great so far but last week I noticed every time I would get ready to go some where, once I started the motor there was about a 2 to 3 minute dealy before the audio kicked in. It would show that I was on a particular XM station or playlist off my ipod. It is a normal thing now. It's like everytime I get in and start the truck up there's a couple of minutes of silence before any audio is played. Any suggestions on whethere it's something to do with the head unit itself or Bose related.
Thanks.
Posted Mar 24, 2012 · 00:04 UTC#2
i would run a few test to figure this out.
first, test to see if the radio is outputing sound right away or if it is not.
if the radio is outputing sound right away, i would check to see if there is a turn on signal right away or not.
your problem is going to either be something wrong with the radio, something wrong with the bose amp, or (probably the most likely) there is something wrong with your bose intergration module.
Posted Mar 27, 2012 · 19:03 UTC#3
Thanks for the info.
Posted Mar 27, 2012 · 22:12 UTC#4
Did you do ny other new installs in the car recently? Like H.I.D.s maybe?
