Avic 930bt Subaru power Sense
By Sargasso · Mar 12, 2012in Problems/Troubleshooting💬 2 posts👁️ 1,391 views
Posted Mar 12, 2012 · 21:46 UTC#1
Hi all, my first post
I have an AVIC 930bt OEM in a 2012 Subaru WRX STI Hatch. I just installed a Sound Ordinance under seat subwoofer and am using the line level sub outputs to drive it. As a result I need the +12v power signal lead to trigger the amp in the sub to power on. According to the install guide for the 930 this is a blue-white lead in the power connector. My problem is there is no blue-white lead. Does anyone know what pin the signal is on. I've tried to find a pin out for the connector on the forums but can't.
Thanks in Advance
Posted Mar 13, 2012 · 22:45 UTC#2
OK I finally found in the "reading wiring" section blue-white can actually mean only blue. Who knew???
Used the blue wire and everything works as expected.
